Aller au contenu principal
LG Optimus L7 P705 SIM Card Slot Replacement
Ce dont vous avez besoin
  1. LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: étape 1, image 1 de 2 LG Optimus L7 P705 SIM Card Slot Replacement, Home Button: étape 1, image 2 de 2
    • Insert a plastic opening tool between the seams of the device and pry the back cover away from the phone.
    • Remove the battery and SIM card.
  2. LG Optimus L7 P705 SIM Card Slot Replacement: étape 2, image 1 de 1
    • Remove the twelve screws using the Phillips 000 screwdriver.
  3. LG Optimus L7 P705 SIM Card Slot Replacement: étape 3, image 1 de 1
    • Remove bottom plate where the charger port is located.
  4. LG Optimus L7 P705 SIM Card Slot Replacement: étape 4, image 1 de 2 LG Optimus L7 P705 SIM Card Slot Replacement: étape 4, image 2 de 2
    • Insert a plastic opening tool between the seams of the device and apply some pressure to lift off the cover.
  5. LG Optimus L7 P705 SIM Card Slot Replacement: étape 5, image 1 de 1
    • Flip over to the face of the device.
    • Lift off the glass screen (display).
  6. LG Optimus L7 P705 SIM Card Slot Replacement: étape 6, image 1 de 1
    • Remove the home screen button. Replace as needed.
  7. LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: étape 7, image 1 de 2 LG Optimus L7 P705 SIM Card Slot Replacement, SIM Card Slot: étape 7, image 2 de 2
    • Flip over to the back of the device
    • Using the plastic spudger, lift off the three board-to-board connectors on the left-hand side of the device.
  8. LG Optimus L7 P705 SIM Card Slot Replacement: étape 8, image 1 de 1
    • Using a plastic spudger, lift off the wire connector at the right bottom of the board.
  9. LG Optimus L7 P705 SIM Card Slot Replacement: étape 9, image 1 de 2 LG Optimus L7 P705 SIM Card Slot Replacement: étape 9, image 2 de 2
    • Detach the mount including both the SIM card and the motherboard from the device.
Yanxiang Ding
Membre depuis le 01/25/17
101 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 2-2, Baechle Spring 2017 Membre de l'équipe IUPUI, Team 2-2, Baechle Spring 2017
IUPUI-BAECHLE-S17S2G2
4 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 3
30 derniers jours : 8
Total : 642
