Introduction
This guide will guide you step-by-step on how to replace the screen on the LG Optimus L9 smartphone. This requires the knowledge of removing the motherboard. Make sure to work in a static-free environment to avoid damaging the components. Make sure to be extra careful with removing the connections as this may lead to permanently damaging them.
Ce dont vous avez besoin
Start by placing the device face down and remove the back cove.
Remove the battery from the phone by lifting it using your finger or the prying tool
Using a spudger or small prying tool, pry off the latches that connects the digitizer to the chassis carefully.
Remove the primary or rear camera using a small opening tool to remove the adhesive and lift the camera up using a pair of tweezers.
Using the same small opening tool, remove the connector that is taped to the chassis of the phone.
