Aller au contenu principal
LG Optimus L9 P769 Motherboard Replacement
Ce dont vous avez besoin
  1. LG Optimus L9 P769 Motherboard Replacement, Motherboard: étape 1, image 1 de 3 LG Optimus L9 P769 Motherboard Replacement, Motherboard: étape 1, image 2 de 3 LG Optimus L9 P769 Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Start by placing the device face down and remove the back cove.
    • Remove the battery from the phone by lifting it using your finger or the prying tool
  2. LG Optimus L9 P769 Motherboard Replacement: étape 2, image 1 de 3 LG Optimus L9 P769 Motherboard Replacement: étape 2, image 2 de 3 LG Optimus L9 P769 Motherboard Replacement: étape 2, image 3 de 3
    • Remove all 10 of the 4.5mm Phillips screws that holds the back frame to the case of the phone
    • Using a small plastic prying tool, carefully remove the back frame by prying on the sides of the device.
    • Do be careful when prying back frame and removing it as too much force may result in damaging the frame.
  3. LG Optimus L9 P769 Motherboard Replacement: étape 3, image 1 de 3 LG Optimus L9 P769 Motherboard Replacement: étape 3, image 2 de 3 LG Optimus L9 P769 Motherboard Replacement: étape 3, image 3 de 3
    • Using tweezers, pinch the sides of the antenna node and pull straight up.
    • Using a small prying tool, carefully remove the ribbon cables attached to the motherboard.
  4. LG Optimus L9 P769 Motherboard Replacement: étape 4, image 1 de 2 LG Optimus L9 P769 Motherboard Replacement: étape 4, image 2 de 2
    • Using a spudger or small prying tool, lift up the motherboard from the chassis of the device.
2 autres ont terminé cette réparation.
Ammar Rizal
Membre depuis le 03/01/17
225 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S2-G1, Harley Spring 2017 Membre de l'équipe IUPUI, Team S2-G1, Harley Spring 2017
IUPUI-HARLEY-S17S2G1
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 10
Total : 500
