Aller au contenu principal
LG Optimus T Motherboard Replacement
Ce dont vous avez besoin
  1. LG Optimus T Motherboard Replacement, Motherboard: étape 1, image 1 de 3 LG Optimus T Motherboard Replacement, Motherboard: étape 1, image 2 de 3 LG Optimus T Motherboard Replacement, Motherboard: étape 1, image 3 de 3
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Using a prying device, such as a plastic opening tool, remove the phone’s back cover. At the top of the phone, there’s an indentation to put the Spudger into to pop the case off
  2. LG Optimus T Motherboard Replacement: étape 2, image 1 de 1
    • Remove the battery. There’s an indentation to the left of the camera lens to pull up on the battery with your finger
  3. LG Optimus T Motherboard Replacement: étape 3, image 1 de 1
    • Use a J0 screwdriver to remove the six 4.5mm screws.
  4. LG Optimus T Motherboard Replacement: étape 4, image 1 de 2 LG Optimus T Motherboard Replacement: étape 4, image 2 de 2
    • You might have difficulty popping the interior case off. You may use the metal spudger here with caution if the plastic opening tool fails
    • Remove interior case. Insert the spudger into the indentations at the top, or bottom of the phone to pry off the interior case.
  5. LG Optimus T Motherboard Replacement: étape 5, image 1 de 1
    • Pull up on connector tab
  6. LG Optimus T Motherboard Replacement: étape 6, image 1 de 2 LG Optimus T Motherboard Replacement: étape 6, image 2 de 2
    • Remove SD card mount. Insert the plastic opening tool on the right side to pop off
  7. LG Optimus T Motherboard Replacement: étape 7, image 1 de 2 LG Optimus T Motherboard Replacement: étape 7, image 2 de 2
    • Remove metal panel
    • There are four retaining points to insert plastic opening tool and pop off panel
  8. LG Optimus T Motherboard Replacement: étape 8, image 1 de 1
    • Use a J0 screwdriver to remove the two 1.8mm screws from charging port. (Charging port and motherboard are connected.)
    • Remove motherboard
stacey
Membre depuis le 02/07/17
219 Réputation
2 tutoriels rédigés
Équipe
Ohio State, Team 1-3, Wilder Spring 2017 Membre de l'équipe Ohio State, Team 1-3, Wilder Spring 2017
OSU-WILDER-S17S1G3
4 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 7
Total : 299
