Aller au contenu principal
LG Optimus V Antenna Replacement
Ce dont vous avez besoin
  1. LG Optimus V Antenna Replacement, Battery: étape 1, image 1 de 1
    • Turn the LG Optimus V over, so that the back cover is facing upward.
  2. LG Optimus V Antenna Replacement: étape 2, image 1 de 1
    • Locate the opening above the camera.
    • Use a spudger to detach the back cover.
  3. LG Optimus V Antenna Replacement: étape 3, image 1 de 3 LG Optimus V Antenna Replacement: étape 3, image 2 de 3 LG Optimus V Antenna Replacement: étape 3, image 3 de 3
    • Gently remove the battery with your spudger.
  4. LG Optimus V Antenna Replacement, Camera: étape 4, image 1 de 2 LG Optimus V Antenna Replacement, Camera: étape 4, image 2 de 2
    • Remove the six screws on the silver casing.
    • Use the plastic opening tool to remove the silver casing.
  5. LG Optimus V Antenna Replacement: étape 5, image 1 de 3 LG Optimus V Antenna Replacement: étape 5, image 2 de 3 LG Optimus V Antenna Replacement: étape 5, image 3 de 3
    • Use a plastic opening tool to remove each area holding the parts together.
  6. LG Optimus V Antenna Replacement: étape 6, image 1 de 2 LG Optimus V Antenna Replacement: étape 6, image 2 de 2
    • Use a plastic opening tool to remove the small black and yellow piece that reads Y3114C.
    • Use a plastic opening tool to pry off the camera.
  7. LG Optimus V Antenna Replacement, Antenna: étape 7, image 1 de 2 LG Optimus V Antenna Replacement, Antenna: étape 7, image 2 de 2
    • Use a soldering iron to desolder the connections attaching the the antenna to the motherboard.
  8. LG Optimus V Antenna Replacement: étape 8, image 1 de 1
    • Solder off the antenna, and solder on the new one. The antenna is now replaced.
3 autres ont terminé cette réparation.
Joseph Pasquantonio
Membre depuis le 10/29/13
683 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team 1-2, Shastany Fall 2013 Membre de l'équipe UMass Dartmouth, Team 1-2, Shastany Fall 2013
UMASSD-SHASTANY-F13S1G2
3 membres
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 6
Total : 2,191
