Introduction
The screen of the LG Optimus Zone 3 is a common part that requires repair. The screen can often crack and instead of discarding the entire device, it is economical and environmentally friendly to just replace the plastic screen overtop of the display.
Pièces
Aucune pièce nécessaire.
  1. Insert fingernail into the slot on the back left side of the phone and pry open.
    • Insert fingernail into the slot on the back left side of the phone and pry open.
  2. Remove faulty battery.
    • Remove faulty battery.
    • The battery is missing from our device, however, it would be located in the section in-between the fingers.
  3. %Livraison gratuite pour toute commande supérieure à 100 $US ou contenant un Pro Tech Toolkit !
    Parcourez notre boutique
  4. Insert the plastic opening tool into the groove between the screen and the rest of the device. Work your way around the perimeter by sliding the opening tool around the edge, loosening the screen.
    • Insert the plastic opening tool into the groove between the screen and the rest of the device. Work your way around the perimeter by sliding the opening tool around the edge, loosening the screen.
  5. Once the screen is loosened, fully remove it from the device by peeling it away from the base of the phone.
    • Once the screen is loosened, fully remove it from the device by peeling it away from the base of the phone.
Cooper Parnell
Membre depuis le 31/01/2018
590 Réputation
5 tutoriels rédigés
Équipe
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 44
Total : 550
