Aller au contenu principal
LG Rebel 4 LTE Disassembly
Ce dont vous avez besoin
  1. LG Rebel 4 LTE Disassembly, Remove the Cover: étape 1, image 1 de 2 LG Rebel 4 LTE Disassembly, Remove the Cover: étape 1, image 2 de 2
    • Locate the indent on the back left side of the phone.
    • Insert the opening tool into the indent and pry until it pops.
    • Remove the backing.
  2. LG Rebel 4 LTE Disassembly, Remove Internal Components: étape 2, image 1 de 3 LG Rebel 4 LTE Disassembly, Remove Internal Components: étape 2, image 2 de 3 LG Rebel 4 LTE Disassembly, Remove Internal Components: étape 2, image 3 de 3
    • Use the spudger to pry the battery out.
    • If installed, pop out the SD/TF card by gently pressing in and releasing the SD card. Not pictured, Located above the Sims card (See Below).
    • Use your fingers to remove the sim card.
  3. LG Rebel 4 LTE Disassembly, Remove Screws: étape 3, image 1 de 3 LG Rebel 4 LTE Disassembly, Remove Screws: étape 3, image 2 de 3 LG Rebel 4 LTE Disassembly, Remove Screws: étape 3, image 3 de 3
    • Using the #000 Phillips screwdriver, remove all the screws (as seen in the photo).
    • There should be 12 screws in total.
    • Don't lose the screws!
  4. LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: étape 4, image 1 de 2 LG Rebel 4 LTE Disassembly, Remove Charging Port Cover: étape 4, image 2 de 2
    • Use the spudger to carefully pry the cover around the charging port.
  5. LG Rebel 4 LTE Disassembly, Remove the Screen: étape 5, image 1 de 3 LG Rebel 4 LTE Disassembly, Remove the Screen: étape 5, image 2 de 3 LG Rebel 4 LTE Disassembly, Remove the Screen: étape 5, image 3 de 3
    • Rotate the phone (view picture) to reveal the top corner of the phone.
    • Using a opening pick, pry in between the glass screen and the framing.
  6. LG Rebel 4 LTE Disassembly, Remove the Motherboard: étape 6, image 1 de 3 LG Rebel 4 LTE Disassembly, Remove the Motherboard: étape 6, image 2 de 3 LG Rebel 4 LTE Disassembly, Remove the Motherboard: étape 6, image 3 de 3
    • Pry from the top and bottom of the screen with the (refer to photo) opening pick to release the tabs holding the motherboard to the phone.
    • Do not let the main camera fall out while removing the mother board.
  7. LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: étape 7, image 1 de 3 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: étape 7, image 2 de 3 LG Rebel 4 LTE Disassembly, Disconnect the Connector Cable: étape 7, image 3 de 3
    • On the bottom right of the phone, locate a cable that holds the motherboard to the phone.
    • Disconnect the cable by gently pulling up on the component with your fingers.
    • Do not use a prying tool or screwdriver to disconnect the cable.
  8. LG Rebel 4 LTE Disassembly, Remove the Camera: étape 8, image 1 de 3 LG Rebel 4 LTE Disassembly, Remove the Camera: étape 8, image 2 de 3 LG Rebel 4 LTE Disassembly, Remove the Camera: étape 8, image 3 de 3
    • Separate the camera from the magnet by gently pulling up.
  9. LG Rebel 4 LTE Disassembly, Disassembly Complete: étape 9, image 1 de 1
    • Congratulations. You've successfully disassembled your device.
    • To reassemble the device, follow these steps in reverse order. (Begin with step 8, continuining until you end on step 1.
    • When reassembling, make sure that each component snaps tightly to the phone before moving to the next step.
JCJR
Membre depuis le 06/23/23
169 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 7
30 derniers jours : 16
Total : 171
