Introduction
Use this guide if you are looking to gain access to the LG Risio Motherboard or other components inside the device.
Pièces
Aucune pièce nécessaire.
Use a plastic opening tool to seperate the back panel from the device.
  • Use a plastic opening tool to seperate the back panel from the device.
  • Remove the back panel.
Ajouter un commentaire
Place your thumb along the bottom of the battery and pry upwards to remove.
  • Place your thumb along the bottom of the battery and pry upwards to remove.
  • Press down on the SIM eject tab with a fingernail (or iFixit opening tool), and slide the SIM card out.
  • Remove the eight Phillips #0 screws from the internal support frame.
  • Use an opening tool on the marked locations to lift the edges up. There should be a small click when lifting these edges up.
  • Using your hand, pick up the midframe to separate it from the phone.
  • If the midframe does not want to lift off, go back and repeat step 6.
Kevin Garcia
Membre depuis le 21/02/2018
159 Réputation
1 tutoriel rédigé
Équipe
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 38
