Aller au contenu principal
LG Sunrise Midframe Replacement
Ce dont vous avez besoin
  1. LG Sunrise Midframe Replacement, Back cover: étape 1, image 1 de 1
    • Flip the phone over so the back side is facing you.
  2. LG Sunrise Midframe Replacement: étape 2, image 1 de 1
    • Use a prying tool or a flat head screwdriver to pry the back cover from the device.
  3. LG Sunrise Midframe Replacement: étape 3, image 1 de 1
    • Set back panel aside for later use or to replace.
  4. LG Sunrise Midframe Replacement, Battery: étape 4, image 1 de 2 LG Sunrise Midframe Replacement, Battery: étape 4, image 2 de 2
    • Use your finger to pull out battery from the bottom of the device.
  5. Attention : les étapes 5 à 6 sont issues d'un tutoriel marqué comme en cours.
    LG Sunrise Midframe Replacement, Lower Back Plastic Piece: étape 5, image 1 de 3 LG Sunrise Midframe Replacement, Lower Back Plastic Piece: étape 5, image 2 de 3 LG Sunrise Midframe Replacement, Lower Back Plastic Piece: étape 5, image 3 de 3
    • You will be first removing the two lower screws. This is allow you to remove the lower plastic piece.
  6. LG Sunrise Midframe Replacement: étape 6, image 1 de 1
    • Once both of the screws are out you can easily pop off the bottom piece.
  7. LG Sunrise Midframe Replacement, Midframe: étape 7, image 1 de 2 LG Sunrise Midframe Replacement, Midframe: étape 7, image 2 de 2
    • Once you have removed all 6 screws. Gently pry all sides of back plastic piece, starting at the bottom. Once you start on the bottom, it will become easier to pry.
  8. LG Sunrise Midframe Replacement: étape 8, image 1 de 2 LG Sunrise Midframe Replacement: étape 8, image 2 de 2
    • Once you have pried off the back piece, the mother board should be exposed. Set this piece aside for replacement or reassembly.
Paxton Fox
Membre depuis le 09/21/18
257 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 1
30 derniers jours : 9
Total : 244
