Ce dont vous avez besoin
Locate the hidden screw as seen in the picture and remove the rubber covering the screw.
Use a guitar pick or any pry opening tool to gently lift the housing until the speaker end. There is a hidden screw that needs to be removed before the housing can be completely removed.
Use a Philips #00 screwdriver to remove the hidden screw.
Remove the screw holding the speaker in place using a Philips #00 screwdriver.
Desolder speaker connection using a soldering iron and replace with new speaker.
2 autres ont terminé cette réparation.
4 commentaires
Do you know of a place to buy a replacement speaker?
Excellent instructions and thank you for your time doing this! Can you give a source for the speaker parts other than LG ?
Again thank you
BT Headphone Neckband type with Retractable Earbud (similar contruction ) :: Do you have instructions for repairing loose connection between earbud and wire for model SX-991
