Ce dont vous avez besoin
Battery is on right side of headset.
First remove rubber cover on the right side of the headset to uncover the hidden screw.
Remove screw using Philips PH00 screwdriver.
Use a guitar pick or any opening tool to pry open the right side.
Once you have opened the right side up until the speaker end, there will be a hidden screw that needs to be unscrewed before the right side can be completely disassembled.
Pry open the speaker back housing with a guitar pick or any opening tool as shown in the picture.
Once the speaker back housing is lifted, you will see the screw.
Remove the screw and the whole right side will be disassembled.
Use a non-metal tool to lift the battery out of place so it will be easy to desolder.
Remember the red wire is positive(+) and the black wire is negative(-).
13 autres ont terminé cette réparation.
2 commentaires
Battery model and amps
Hello budy!
Tanks for the guide, i was going crazy looking for that hidden screw!
You might be able to help me. Would you know what i must look for a malfunctioning earbud? My right one suddenly died and im hoping the cord isn't broken and its just some loose weld.
