Aller au contenu principal
LG Tone Infinim HBS-910 Battery Replacement
Ce dont vous avez besoin
  1. LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: étape 1, image 1 de 3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: étape 1, image 2 de 3 LG Tone Infinim HBS-910 Battery Replacement, Locate right side.: étape 1, image 3 de 3
    • Battery is on right side of headset.
    • First remove rubber cover on the right side of the headset to uncover the hidden screw.
    • Remove screw using Philips PH00 screwdriver.
  2. LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: étape 2, image 1 de 2 LG Tone Infinim HBS-910 Battery Replacement, Disassemble right side.: étape 2, image 2 de 2
    • Use a guitar pick or any opening tool to pry open the right side.
  3. LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: étape 3, image 1 de 3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: étape 3, image 2 de 3 LG Tone Infinim HBS-910 Battery Replacement, Hidden screw.: étape 3, image 3 de 3
    • Once you have opened the right side up until the speaker end, there will be a hidden screw that needs to be unscrewed before the right side can be completely disassembled.
    • Pry open the speaker back housing with a guitar pick or any opening tool as shown in the picture.
    • Once the speaker back housing is lifted, you will see the screw.
    • Remove the screw and the whole right side will be disassembled.
  4. LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: étape 4, image 1 de 3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: étape 4, image 2 de 3 LG Tone Infinim HBS-910 Battery Replacement, Desolder battery.: étape 4, image 3 de 3
    • Use a non-metal tool to lift the battery out of place so it will be easy to desolder.
    • Remember the red wire is positive(+) and the black wire is negative(-).
13 autres ont terminé cette réparation.
Faizan Naveed
Membre depuis le 04/12/17
3 294 Réputation
8 tutoriels rédigés
Équipe
Mobile Device Repair Factory Membre de l'équipe Mobile Device Repair Factory
Business
1 membre
16 tutoriels rédigés
2 commentaires
Battery model and amps
honda kung - Réponse
Hello budy!
Tanks for the guide, i was going crazy looking for that hidden screw!
You might be able to help me. Would you know what i must look for a malfunctioning earbud? My right one suddenly died and im hoping the cord isn't broken and its just some loose weld.
Rafael Zerbini - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 6
30 derniers jours : 27
Total : 11,263
