Aller au contenu principal
LG Tone Pro HBS-760 Speaker Replacement
Ce dont vous avez besoin
  1. LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: étape 1, image 1 de 3 LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: étape 1, image 2 de 3 LG Tone Pro HBS-760 Speaker  Replacement, Locate Hidden Screw: étape 1, image 3 de 3
    • Locate the right and left side speaker where the hidden screw is located and remove the rubber piece covering the screw.
  2. LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: étape 2, image 1 de 2 LG Tone Pro HBS-760 Speaker  Replacement, Remove Hidden Screw: étape 2, image 2 de 2
    • Using a Philips #00 screwdriver, remove the hidden screws from both sides.
  3. LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: étape 3, image 1 de 3 LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: étape 3, image 2 de 3 LG Tone Pro HBS-760 Speaker  Replacement, Pry Open Housing: étape 3, image 3 de 3
    • Use a guitar pick or any opening tool to pry open the housing for the side you want to replace the speaker.
  4. LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: étape 4, image 1 de 3 LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: étape 4, image 2 de 3 LG Tone Pro HBS-760 Speaker  Replacement, Desolder Speaker: étape 4, image 3 de 3
    • Right side can be de-soldered right away but the left side speaker solder connection to the board is covered by rubber material which needs to be removed first before it can be de-soldered.
  5. LG Tone Pro HBS-760 Speaker  Replacement, Replace Speakers: étape 5, image 1 de 1
    • Once the speakers have been de-soldered, replace with new ones.
2 autres ont terminé cette réparation.
Faizan Naveed
Membre depuis le 04/12/17
3 294 Réputation
8 tutoriels rédigés
Équipe
Mobile Device Repair Factory Membre de l'équipe Mobile Device Repair Factory
Business
1 membre
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 25
Total : 1,509
