Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Pièces
  1. Find the side of the device with the defective magnet. Remove the rubber piece on the underside of the device that protects the screw. Find the side of the device with the defective magnet. Remove the rubber piece on the underside of the device that protects the screw.
    • Find the side of the device with the defective magnet. Remove the rubber piece on the underside of the device that protects the screw.
  2. Remove the small screw from the underside of the device and place it aside.
    • Remove the small screw from the underside of the device and place it aside.
  3. Place a small prying tool in between the two cases and slowly push the two apart. Be sure not to force the case apart, as it may snap in the process.
    • Place a small prying tool in between the two cases and slowly push the two apart. Be sure not to force the case apart, as it may snap in the process.
  4. Kits pour Nintendo Switch
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Once the case is open, the small magnet is now visible and can be replaced.
    • Once the case is open, the small magnet is now visible and can be replaced.
  6. Once the new magnet is in place, the casing can be pushed back together.
    • Once the new magnet is in place, the casing can be pushed back together.
  7. The small screw that was taken out at the beginning can be screwed back into the device.
    • The small screw that was taken out at the beginning can be screwed back into the device.
  8. Push the small rubber piece back into place over the screw.
    • Push the small rubber piece back into place over the screw.
Ligne d'arrivée
6 autre(s) ont terminé cette réparation.
Andrew Oglesby
Membre depuis le 31/03/2015
246 Réputation
1 tutoriel rédigé
Équipe
UMass Dartmouth, Team 2-2, Shastany Spring 2015 Membre de l'équipe UMass Dartmouth, Team 2-2, Shastany Spring 2015
UMASSD-SHASTANY-S15S2G2
3 membres
1 tutoriel rédigé
Thanks for your instruction. Tell me please what is the thickness of the ear cords is it possible to connect them back after it was teared off? I want to buy broken on the ebay and fix it but I can't understand if it possible to fix it without looking on the cords.
macosrus - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 5
30 derniers jours : 22
Total : 2,441
