Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
This guide will explain how to replace the Auxiliary Port (headphone jack) on the LG Treasure.
Pièces
Aucune pièce spécifiée.
  1. Make sure the LG Treasure is turned off. Pull off the back cover from the phone using the groove on the bottom right side.
    • Make sure the LG Treasure is turned off.
    • Pull off the back cover from the phone using the groove on the bottom right side.
  2. Remove the battery from the phone by lifting up on the bottom end of the battery.
    • Remove the battery from the phone by lifting up on the bottom end of the battery.
  3. Manta Precision Bit Set
    112 embouts pour toute réparation.
    Upgrade Your Toolbox
  4. Remove all 9 of the 3mm Phillips #000 screws from the digitizer. Work your way around the edge of the phone, gently prying the digitizer off the phone.
    • Remove all 9 of the 3mm Phillips #000 screws from the digitizer.
    • Work your way around the edge of the phone, gently prying the digitizer off the phone.
  5. Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out. Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out. Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out.
    • Insert your finger nail into the groove under the Auxiliary Port and pry the Auxiliary Port out.
david amirahmadi
Membre depuis le 15/02/2018
546 Réputation
5 tutoriels rédigés
Équipe
UW Stout, Team S8-G5, Ogden Spring 2018 Membre de l'équipe UW Stout, Team S8-G5, Ogden Spring 2018
UWSTOUT-OGDEN-S18S8G5
3 membres
5 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 2
Total : 147
