Aller au contenu principal
LG UD501KOJ5 Dehumidifier Sensor Replacement
Ce dont vous avez besoin
  1. LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: étape 1, image 1 de 2 LG UD501KOJ5 Dehumidifier Sensor Replacement, Humidity Sensor: étape 1, image 2 de 2
    • Unplug the dehumidifier then put on work gloves to protect your hands.
    • Remove the water collection bucket and set it aside.
    • Remove the air filter from the bottom of the front grille.
  2. LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 2, image 1 de 2 LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 2, image 2 de 2
    • Using your Phillips #0 screwdriver, remove the two screws which are attached at the bottom of the front grille.
    • Lift the front grille up and off the front of the frame, carefully set it in front of the dehumidifier.
    • The control board wire harness is still attached to the back of the front grille.
  3. LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 3, image 1 de 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 3, image 2 de 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 3, image 3 de 3
    • Remove the screws that secure the back panel to the dehumidifier.
    • Carefully remove the back panel from the dehumidifier.
    • Remove the screws at the side.
  4. LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 4, image 1 de 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 4, image 2 de 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 4, image 3 de 3
    • Remove the screws located at both sides of the back panel.
    • Remove the screws on the top left and top right which are connected to the control box.
    • Carefully remove the outer case.
  5. LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 5, image 1 de 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 5, image 2 de 3 LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 5, image 3 de 3
    • Disconnect the sensor wire harness from the electronic control board.
    • Disconnect the wire harness from the collection bucket float switch.
    • Pull the evaporator thermistor out of the copper sleeve on the side of the evaporator coil.
  6. LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 6, image 1 de 2 LG UD501KOJ5 Dehumidifier Sensor Replacement: étape 6, image 2 de 2
    • Remove the humidity sensor from the evaporator fins.
    • Pull the sensor assembly out of the dehumidifier.
    • Remove any dust build-up with a dry cloth.
    • Push the new humidity sensor in place on the front of the evaporator fins.
Gabrielle Campbell
Membre depuis le 05/12/21
133 Réputation
1 tutoriel rédigé
Équipe
York University, Team S1-G3, O'Regan Summer 2021 Membre de l'équipe York University, Team S1-G3, O'Regan Summer 2021
YORK-O'REGAN-SU21S1G3
1 membre
1 tutoriel rédigé
Un commentaire
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 7
30 derniers jours : 33
Total : 2,391
