Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
Use this guide to remove the rear lens cover of your LG V20.
  1. Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone. Remove the back cover. Remove the back cover.
    • Press the button on the lower right side of the LG V20 to open the clamp that holds the back cover on the back side of the phone.
    • Remove the back cover.
  2. Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured. Use the flat end of a spudger and insert it in the small recess at the lower end of the battery. Use the spudger to lever out the battery and remove it.
    • Before disassembling your phone, discharge the battery below 25%. A charged lithium-ion battery can catch fire and/or explode if accidentally punctured.
    • Use the flat end of a spudger and insert it in the small recess at the lower end of the battery.
    • Use the spudger to lever out the battery and remove it.
    • You can do this with your fingers but take care not to puncture the battery with your fingernails.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Use an iOpener to loosen the adhesive beneath the rear lens cover.
  5. Use the tip of an opening pick to gently pry up the rear lens cover. Use the tip of the opening pick and slide around the whole rear lens cover to cut the adhesive beneath. Use the tip of the opening pick and slide around the whole rear lens cover to cut the adhesive beneath.
    • Use the tip of an opening pick to gently pry up the rear lens cover.
    • Use the tip of the opening pick and slide around the whole rear lens cover to cut the adhesive beneath.
  6. Remove the rear lens cover.
    • Remove the rear lens cover.
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it’s necessary.
5 autre(s) ont terminé cette réparation.
Dominik Schnabelrauch
Membre depuis le 23/11/2016
64 535 Réputation
292 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
125 membres
11 822 tutoriels rédigés
Need to be careful not to pull the flash bits as well.
David Nevill - Réponse
My rear camera lens cover stack fell off. The flash array, the two cameras and the sensors on the right are in place. The rubber 'rings' around the flash and sensors are gone and everything above them is gone.
How do I get all of the pieces?
Is it called a “lens cover stack" or something like that?
Bill Lipe - Réponse
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 5
7 derniers jours : 8
30 derniers jours : 53
Total : 1,500
