Aller au contenu principal
LG VS810 Screen Replacement
Ce dont vous avez besoin
    • Remove the back cover
    • Remove the battery , SIM card, and SD card
    • Unscrew the 8 screws using a Phillips (PH#00) screwdriver
    • Using a plastic opening tool , once again pry up on the edges of the plastic back cover.
    • Working on a magnet board is recommended as the screws are small and can be easily misplaced
    • Gently disconect the screen cable using a spudger.
    • Using the spudger, pry the motherboard away from the screen assembly.
    • Use a heat gun or hairdryer to heat up the edges. This will loosen the glue so the screen can be removed.
    • Continue to heat and separate until the screen comes completely apart from the rest of the phone using plastic tools
    • The phone will be extremely hot. Avoid direct contact with metal pieces.
7 autres ont terminé cette réparation.
[deleted]
Membre depuis le 10/25/15
398 Réputation
1 tutoriel rédigé
Un commentaire
Pls help how can I fix lg-k120e screen
drammehoumar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 9
Total : 4,348
