Aller au contenu principal
LG VX4500 keyboard replacement duplicate
Tutoriel Archivé
Ce tutoriel est conservé uniquement à des fins de suivis historiques. Utilisez la version actuelle du tutoriel pour effectuer votre réparation.
Ce dont vous avez besoin
  1. LG VX4500 keyboard replacement duplicate, Battery: étape 1, image 1 de 1
    • Before removing the battery, ensure that the phone is turned off.
    • To remove the battery from your LG VX4500, turn the phone so that the back panel is showing.
  2. LG VX4500 keyboard replacement duplicate: étape 2, image 1 de 1
    • Pull back on the white release tab and lift up the the entire battery.
  3. LG VX4500 keyboard replacement duplicate: étape 3, image 1 de 1
    • The back panel should now be fully accessible.
  4. LG VX4500 keyboard replacement duplicate, LG VX4500 Disassembly: étape 4, image 1 de 2 LG VX4500 keyboard replacement duplicate, LG VX4500 Disassembly: étape 4, image 2 de 2
    • Using a paper clip, remove all 4 rubber screwcaps from the screw ports.
    • With a Phillips head screwdriver, remove all 4 screws from their ports.
    • Also remove the rubber screwcap in the upper part of the back panel along with the screw under it.
    • The fifth screw will be more difficult to get out because the plastic port has much higher sides.
  5. LG VX4500 keyboard replacement duplicate: étape 5, image 1 de 3 LG VX4500 keyboard replacement duplicate: étape 5, image 2 de 3 LG VX4500 keyboard replacement duplicate: étape 5, image 3 de 3
    • Run a plastic opening tool along the seam to seperate the keyboard cover and the back panel
    • Remove the back panel, now the logic board, keyboard and microphone are exposed.
  6. LG VX4500 keyboard replacement duplicate, Logic Board: étape 6, image 1 de 2 LG VX4500 keyboard replacement duplicate, Logic Board: étape 6, image 2 de 2
    • With your fingers, gently lift up the gold connector until it is completely disconnected.
  7. LG VX4500 keyboard replacement duplicate, Keyboard: étape 7, image 1 de 1
    • Move the logic board out of the way to reveal the keyboard underneath.
  8. LG VX4500 keyboard replacement duplicate: étape 8, image 1 de 2 LG VX4500 keyboard replacement duplicate: étape 8, image 2 de 2
    • Pop the keyboard out using a your finger until the entire keyboard is out.
iDeleted
Membre depuis le 07/07/10
2 101 Réputation
39 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 10
Total : 328
