Aller au contenu principal
Introduction
A guide to replace the antenna.
Pièces
Aucune pièce spécifiée.
  1. Turn the phone on its back. Turn the phone on its back.
    • Turn the phone on its back.
  2. Orient the phone as shown. Remove the battery cover by pushing upward with your thumb.
    • Orient the phone as shown.
    • Remove the battery cover by pushing upward with your thumb.
  3. Place your fingernail at the top of the battery and pry the battery out towards you. Place your fingernail at the top of the battery and pry the battery out towards you.
    • Place your fingernail at the top of the battery and pry the battery out towards you.
  4. Orient the phone as shown with the battery already removed.
    • Orient the phone as shown with the battery already removed.
  5. Fix Kits pour Android
    Remplacer l'écran ou la batterie est à portée de kit !
    Acheter maintenant
    Acheter maintenant
  6. Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards. Use a Phillips #00 screwdriver to remove the 5 screws as shown here. Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
    • Remove the 2 plastic plugs located on the side and upper quadrant of the rear body panel by using the push-pin and lifting outwards.
    • Use a Phillips #00 screwdriver to remove the 5 screws as shown here.
  7. Place an iPod opener tool in the seam above the antenna. Run the tool around the perimeter of the entire phone. Run the tool around the perimeter of the entire phone.
    • Place an iPod opener tool in the seam above the antenna.
    • Run the tool around the perimeter of the entire phone.
  8. Check to see that your device looks like the attached photo.
    • Check to see that your device looks like the attached photo.
  9. Locate the screw and copper fixture that hold the antenna in place.
    • Locate the screw and copper fixture that hold the antenna in place.
    • Remove the screw from the device using a Philips #00 screwdriver.
  10. Remove the copper fixture after it has been unscrewed. Remove the copper fixture after it has been unscrewed.
    • Remove the copper fixture after it has been unscrewed.
  11. Check to see that your device looks like the attached photo. Check to see that your device looks like the attached photo.
Douglas Blaalid
Membre depuis le 13/01/2010
282 Réputation
8 tutoriels rédigés
Équipe
Cal Poly, Team 4-13, Forte Winter 2010 Membre de l'équipe Cal Poly, Team 4-13, Forte Winter 2010
CPSU-FORTE-W10S4G13
5 membres
15 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 2,315
