Aller au contenu principal
LG VX5200 Screen Replacement
Ce dont vous avez besoin
  1. LG VX5200 Screen Replacement, Screen: étape 1, image 1 de 3 LG VX5200 Screen Replacement, Screen: étape 1, image 2 de 3 LG VX5200 Screen Replacement, Screen: étape 1, image 3 de 3
    • Pry the grey pieces of plastic off the corners of the screen with a spudger.
  2. LG VX5200 Screen Replacement: étape 2, image 1 de 2 LG VX5200 Screen Replacement: étape 2, image 2 de 2
    • Unscrew each of the four screws with a Phillips #00 Screwdriver.
    • These screws are the same size as the ones from the back casing, but are not the same size as the screw from the antenna.
  3. LG VX5200 Screen Replacement: étape 3, image 1 de 2 LG VX5200 Screen Replacement: étape 3, image 2 de 2
    • Close the phone after removing the screws.
    • Slide a spudger into the cracks in the top half of the phone's casing.
    • Wedge and lever the spudger to remove the casing.
    • Apply constant pressure to avoid cracking the plastic casing. This step can take a few minutes.
  4. LG VX5200 Screen Replacement: étape 4, image 1 de 3 LG VX5200 Screen Replacement: étape 4, image 2 de 3 LG VX5200 Screen Replacement: étape 4, image 3 de 3
    • Remove the chipboard from the screen by sliding a plastic spudger under the screen and lifting.
    • Use a plastic spudger to avoid short-circuiting the phone's electronics.
    • Gently lift the speaker out of the plastic casing using a plastic spudger.
    • Remove the small battery adjacent to the speaker with a plastic spudger.
  5. LG VX5200 Screen Replacement: étape 5, image 1 de 3 LG VX5200 Screen Replacement: étape 5, image 2 de 3 LG VX5200 Screen Replacement: étape 5, image 3 de 3
    • Slide and lever a plastic spudger between the screen and it's housing.
    • Avoid tearing the wires connecting the screen, the small battery and the speaker.
    • Remove the chip connecting the screen to the camera using your fingers.
jmarcum
Membre depuis le 10/28/09
16 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 9-18, Regan Fall 2009 Membre de l'équipe Cal Poly, Team 9-18, Regan Fall 2009
CPSU-REGAN-F09S9G18
5 membres
2 tutoriels rédigés
Un commentaire
The “battery” beside the speaker isn’t the battery, it’s the phone vibrator. Still a good guide, however
Kaleb White - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 3,392
