Aller au contenu principal
LG VX5300 Keypad Replacement
Ce dont vous avez besoin
  1. LG VX5300 Keypad Replacement, Disassembling Back Cover: étape 1, image 1 de 3 LG VX5300 Keypad Replacement, Disassembling Back Cover: étape 1, image 2 de 3 LG VX5300 Keypad Replacement, Disassembling Back Cover: étape 1, image 3 de 3
    • Carefully slide battery cover off in a downward direction.
    • Using the plastic opening tool, remove the battery. Light force may be necessary.
  2. LG VX5300 Keypad Replacement: étape 2, image 1 de 1
    • Using a Phillips #0 screwdriver, remove the five screws from the back cover and carefully set them aside.
  3. LG VX5300 Keypad Replacement: étape 3, image 1 de 1
    • Using the plastic opening tool, carefully lift the back cover off.
  4. LG VX5300 Keypad Replacement, Keypad: étape 4, image 1 de 2 LG VX5300 Keypad Replacement, Keypad: étape 4, image 2 de 2
    • Before touching anything inside the phone: it is crucial that you are very cautious when working around the wiring and sensor bars.
    • Look to the following photo for the location of the two sensor bars.
    • Without disconnecting the orange wire, carefully flip the computer chip over and lay flat on the table, exposing the keypad.
  5. LG VX5300 Keypad Replacement: étape 5, image 1 de 2 LG VX5300 Keypad Replacement: étape 5, image 2 de 2
    • Carefully remove the keypad and replace with the new keypad.
    • If sensor bars behind the volume and camera buttons fall out, gently put them back in place behind the buttons.
  6. LG VX5300 Keypad Replacement: étape 6, image 1 de 1
    • Carefully set the computer chip back in place.
  7. LG VX5300 Keypad Replacement: étape 7, image 1 de 2 LG VX5300 Keypad Replacement: étape 7, image 2 de 2
    • Place the back cover back on and secure it with the screws.
  8. LG VX5300 Keypad Replacement: étape 8, image 1 de 2 LG VX5300 Keypad Replacement: étape 8, image 2 de 2
    • Insert the battery.
    • Slide the back cover on the phone.
Ligne d'arrivée
Ashley
Membre depuis le 02/12/13
13 Réputation
3 tutoriels rédigés
Équipe
Ohio State, Team 1-1, Buehl Spring 2013 Membre de l'équipe Ohio State, Team 1-1, Buehl Spring 2013
OSU-BUEHL-S13S1G1
3 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 573
