Aller au contenu principal
LG VX7000 External LCD Display Replacement
Ce dont vous avez besoin
  1. LG VX7000 External LCD Display Replacement, External LCD Display: étape 1, image 1 de 1
    • Using a pair of tweezers, remove the rubber screw covers located at each corner of the main screen.
    • NOTE: There will be a total of four rubber screw covers removed.
    • Turn the screwdriver counterclockwise to unscrew the screws located under the recently removed rubber plugs.
    • NOTE: The screws can not be completely removed from their holes.
  2. LG VX7000 External LCD Display Replacement: étape 2, image 1 de 1
    • Using the "iPod Opening Tool", separate the faceplate from the front of the phone.
    • NOTE: There will be a significant amount of resistance when separating the faceplate from the phone.
    • Align the new faceplate in the place of the previously cracked faceplate, and press the new faceplate onto the phone.
Nichole Shaw
Membre depuis le 04/13/10
1 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 18-75, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 membres
14 tutoriels rédigés
Un commentaire
My phone turns on but the screen is black I think because one side of the phone the is broken where you flip it open it opens but you just can't see the screen
chayp62 - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 6
30 derniers jours : 15
Total : 1,702
