Introduction
Replace a cracked internal LCD display.
Note: to replace the internal display, you must replace the entire face plate, not just the plastic screen.
Ce dont vous avez besoin
Outil utilisé dans cette étape :Tweezers$4.99
Using Tweezers, remove 4 rubber screw covers.
Remove screws located under rubber plugs using the screwdriver by turning counterclockwise.
