Aller au contenu principal
Introduction
Replace damaged keypad.
Pièces
Aucune pièce spécifiée.
  1. Lay the phone face down with the screen in palm of hand.
    • Lay the phone face down with the screen in palm of hand.
    • Slide the grey button towards the top of the phone.
  2. While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • Pull the battery up vertically to completely remove from phone.
  3. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  4. Locate four screws underneath of the battery.
    • Locate four screws underneath of the battery.
    • Remove screws by turning counter clockwise with screwdriver until they pop out.
  5. Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
    • Place fingers on bottom of phone near charger adapter and pry back half of bottom apart.
    • Note: There will be a significant amount of resistance.
  6. Lift up logic board without completely removing from phone.
    • Lift up logic board without completely removing from phone.
    • Remove entire keypad from beneath the logic board.
  7. Insert replacement keypad with buttons aligned in proper holes.
    • Insert replacement keypad with buttons aligned in proper holes.
Nichole Shaw
Membre depuis le 13/04/2010
1 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 18-75, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 membres
14 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 999
