Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Boutique
Introduction
Phone lacking intelligence? Replace your logic board.
Pièces
Aucune pièce spécifiée.
  1. Lay the phone face down with the screen in palm of hand.
    • Lay the phone face down with the screen in palm of hand.
    • Slide the grey button towards the top of the phone.
  2. While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • While the button is slid up grab the battery on the sides and pull up with the bottom remaining in place.
    • Pull the battery up vertically to completely remove from phone.
  3. SAUTEZ LA MISE À NIVEAU
    Économisez en réparant avec un kit tout-en-un.
    Fix Kits pour iPhone
  4. Remove four screws beneath battery using screw driver.
    • Remove four screws beneath battery using screw driver.
    • Remove three rubber screw covers with tweezers.
    • Remove the three screws under the covers with the screwdriver.
  5. Detach outer casing from back of phone.
    • Detach outer casing from back of phone.
    • NOTE: There will be a significant amount of resistance to detaching the back casing.
  6. Unsnap gold rectangular plate and silver square plate from the logic board.
    • Unsnap gold rectangular plate and silver square plate from the logic board.
  7. Remove logic board, being careful not to remove any other pieces.
    • Remove logic board, being careful not to remove any other pieces.
    • Insert new logic board with white side facing down.
    • NOTE: Make sure side buttons on logic board are correctly aligned to avoid future complications.
Nichole Shaw
Membre depuis le 13/04/2010
1 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 18-75, Johann Spring 2010 Membre de l'équipe Cal Poly, Team 18-75, Johann Spring 2010
CPSU-JOHANN-S10S18G75
4 membres
14 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 1,250
