Introduction
The number button pad may sometimes require cleaning or replacement. This guide describes the steps required to remove the button pad. It is a simple process, but you will need patience and a few tools.
Ce dont vous avez besoin
Power off the device by holding down the red button labeled PWR.
Remove the battery pack cover by pushing down on the solid lines at the top end of the cover. Slide the cover down while applying the pushing force at the top to remove the cover completely.
Holding the chassis firmly in one hand, then lift up on the charging port with the edge of an opening tool to separate the logic board from the front body case.
Use the spudger tool to gently lift the board out of the case. The board is secured by six holes around its perimeter and will become free when pried from the supports.
Without putting tension on the wiring, remove the speakers one at a time.
Remove the ribbon cable by lifting it up with your finger. Set it aside.
Remove the logic board completely from the case and set it aside. You can now remove the button pad with your fingers or the spudger tool.
Follow these instructions in reverse order to reassemble the device.
