Aller au contenu principal
LG VX8550 Motherboard Replacement
Ce dont vous avez besoin
  1. LG VX8550 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Slide the battery release up.
  2. LG VX8550 Motherboard Replacement: étape 2, image 1 de 1
    • Remove the battery by lifting away from the case.
  3. LG VX8550 Motherboard Replacement, Case: étape 3, image 1 de 1
    • Remove the 2 screw covers next to the rear speaker with a Push Pin.
  4. LG VX8550 Motherboard Replacement: étape 4, image 1 de 1
    • Remove the 4 cover screws with a Philips #00 screwdriver.
  5. LG VX8550 Motherboard Replacement: étape 5, image 1 de 1
    • Use the iPod opening tool to pry off the back casing.
  6. LG VX8550 Motherboard Replacement: étape 6, image 1 de 1
    • Continue sliding the iPod opening tool around the seam of the casing to separate the front and back casings.
  7. LG VX8550 Motherboard Replacement: étape 7, image 1 de 1
    • Separate the casing halves.
    • Be sure to keep track of the side buttons as they fall out.
  8. LG VX8550 Motherboard Replacement, Motherboard: étape 8, image 1 de 1
    • Remove the 2 screws from the back of the phone with a Phillips #00 Screwdriver.
  9. LG VX8550 Motherboard Replacement: étape 9, image 1 de 1
    • Carefully lift up on the motherboard to see the ribbon cables underneath.
    • Use the spudger to carefully disconnect the ribbon cable from the motherboard.
  10. LG VX8550 Motherboard Replacement: étape 10, image 1 de 1
    • Remove the motherboard from the front casing by lifting straight up.
Nathan Jones
Membre depuis le 04/10/10
89 Réputation
10 tutoriels rédigés
Équipe
Cal Poly, Team 34-55, Forte Spring 2010 Membre de l'équipe Cal Poly, Team 34-55, Forte Spring 2010
CPSU-FORTE-S10S34G55
5 membres
20 tutoriels rédigés
Un commentaire
It is a nice way to remove the motherboard of the LG mobile i did not done it but your have done it very nicely and with a great way. thanks for this good post i really enjoy the reading.
http://harrypotter1081.livejournal.com/
Harry Potter - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 1
Total : 2,477
