Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Pièces
Aucune pièce spécifiée.
  1. Turn the phone off. Remove the back cover by sliding the tab away from the phone using one finger.
    • Turn the phone off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. Lift one side of the battery using a plastic opening tool or your fingers.
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
  3. When installing the battery, make sure to align the metal pins with those of the phone.
    • When installing the battery, make sure to align the metal pins with those of the phone.
  4. Fix Kits pour écrans LCD d'iPhone
    L'option économique couverte par notre garantie à vie.
    Acheter des kits
    Réduisez les coûts de réparation et non pas la qualité.
    Acheter des kits
  5. Turn your phone around and open the flip phone.
    • Turn your phone around and open the flip phone.
    • Locate the two grey rubber plugs on the LCD portion of the phone. These plugs cover up two screws.
    • Remove the two grey screw-covers at the bottom of the screen
  6. Remove the screen by using the tab to eject the screen. There is a gap between the case and the screen near the ear piece
    • Remove the screen by using the tab to eject the screen.
    • There is a gap between the case and the screen near the ear piece
    • Insert the plastic opening tool in the gap and pry the screen up.
    • The plastic screen cover is glued onto the phone, do not be alarmed if it may be difficult to pry it off.
  7. Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
    • Unscrew the four corner 3.21mm screws to separate the the top cover of the phone
  8. Turn your phone around Remove the top cover of the phone by inserting the plastic opening tool into the groove.
    • Remove the top cover of the phone by inserting the plastic opening tool into the groove.
    • Carefully open the cover.
Stanley Thomas
Membre depuis le 20/01/2012
41 Réputation
4 tutoriels rédigés
Équipe
Cal Poly, Team 8-16, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 membres
14 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 0
Total : 905
