Aller au contenu principal
LG VX8700 Keypad Replacement
Ce dont vous avez besoin
  1. LG VX8700 Keypad Replacement, Battery: étape 1, image 1 de 2 LG VX8700 Keypad Replacement, Battery: étape 1, image 2 de 2
    • Make sure the phone is completely off.
    • Remove the back cover by sliding the tab away from the phone using one finger.
  2. LG VX8700 Keypad Replacement: étape 2, image 1 de 2 LG VX8700 Keypad Replacement: étape 2, image 2 de 2
    • Lift one side of the battery using a plastic opening tool or your fingers.
    • Carefully remove the battery and set it aside.
    • When installing the new battery, make sure to align the metal pins with those of the phone.
  3. LG VX8700 Keypad Replacement, Keypad: étape 3, image 1 de 2 LG VX8700 Keypad Replacement, Keypad: étape 3, image 2 de 2
    • Remove the nine 4 mm screws from the back cover with a Phillips #0 screwdriver.
  4. LG VX8700 Keypad Replacement: étape 4, image 1 de 2 LG VX8700 Keypad Replacement: étape 4, image 2 de 2
    • Insert the tip of the iFixit opening tool into the small notch on the side of the case.
    • Slide the opening tool along the seam and around the edge of the phone to separate the case.
  5. LG VX8700 Keypad Replacement: étape 5, image 1 de 1
    • Separate the two halves of the phone.
    • The back of the phone, which houses the motherboard and keypad, is displayed on the left.
    • The plastic casing is displayed on the right.
  6. LG VX8700 Keypad Replacement: étape 6, image 1 de 3 LG VX8700 Keypad Replacement: étape 6, image 2 de 3 LG VX8700 Keypad Replacement: étape 6, image 3 de 3
    • Hold the phone casing with one hand and the keypad assembly with the other.
    • Separate the phone casing from the keypad/motherboard.
  7. LG VX8700 Keypad Replacement: étape 7, image 1 de 2 LG VX8700 Keypad Replacement: étape 7, image 2 de 2
    • Pull the two boards apart to separate the keypad from the motherboard.
tnscholz
Membre depuis le 01/20/12
18 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 8-16, Maness Winter 2012 Membre de l'équipe Cal Poly, Team 8-16, Maness Winter 2012
CPSU-MANESS-W12S8G16
4 membres
14 tutoriels rédigés
Un commentaire
When I separated the two halves a small brass piece came out and your instructions do not show nor mention what this is or where it goes. Not even a caution about it coming out upon separation of the halves. It appears to belong on one of the screw posts and because it is brass I believe it is supposed to complete a circuit.
gfon - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 14
Total : 737
