Introduction
The front keypad suffers a lot of wear-and-tear, but can be easily replaced. This guide will show you how to remove the old keypad so that you may install a new one.
Ce dont vous avez besoin
Remove the two triangular pads at the top of the two speakers.
These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
