Aller au contenu principal
LG VX9800 Logic Board Replacement
Ce dont vous avez besoin
  1. LG VX9800 Logic Board Replacement, Front Keypad: étape 1, image 1 de 1
    • Remove the two triangular pads at the top of the two speakers.
    • These pads have adhesive to keep them situated, so you may want to use a fine-tipped object, such as a screwdriver or a pen, to remove them. It is easiest to place the fine-tipped object in the small indent in the corner of these pads.
  2. LG VX9800 Logic Board Replacement: étape 2, image 1 de 1
    • Remove the two rubber cylinders from their shafts. These cover more screws.
    • This requires a little more effort, so you may need to "dig" them out.
  3. LG VX9800 Logic Board Replacement: étape 3, image 1 de 1
    • Now remove the four screws.
    • The screws are small, so put them somewhere that you can easily keep track of them.
  4. LG VX9800 Logic Board Replacement: étape 4, image 1 de 1
    • Starting on the side with blue square, pry the faceplate upwards with the flat end of a spudger.
    • Continue to slide the flat edge along the seam of the faceplate.
    • You should hear popping or snapping noises as the faceplate is being removed.
  5. LG VX9800 Logic Board Replacement: étape 5, image 1 de 2 LG VX9800 Logic Board Replacement: étape 5, image 2 de 2
    • The faceplate is attached by wires, so do not pull the faceplate very far away from the phone.
  6. LG VX9800 Logic Board Replacement: étape 6, image 1 de 3 LG VX9800 Logic Board Replacement: étape 6, image 2 de 3 LG VX9800 Logic Board Replacement: étape 6, image 3 de 3
    • The faceplate is still attached through speakers that travel from the ear-piece to the motherboard.
    • Carefully wedge the flat or pointed end of the spudger beneath the ear-piece and the faceplate.
    • This may require a bit of force, as the ear-piece is stuck to the faceplate with adhesive.
  7. LG VX9800 Logic Board Replacement: étape 7, image 1 de 1
    • The faceplate and keypad can now be completely removed from the phone.
  8. LG VX9800 Logic Board Replacement, Logic Board: étape 8, image 1 de 3 LG VX9800 Logic Board Replacement, Logic Board: étape 8, image 2 de 3 LG VX9800 Logic Board Replacement, Logic Board: étape 8, image 3 de 3
    • Use Spudger to pry against the side side of the phone and the logic board to release it.
    • The logic board is connected to a thin silver piece of metal highlighted with a blue square in the photo. Pry against this piece and the phone to release the board.
    • The logic board is connected to the phone and speaker with the set of connections highlighted with a red circle. Do not yank on the board once its released
  9. LG VX9800 Logic Board Replacement: étape 9, image 1 de 1
    • Remove 4 wires from logic board. Replace board by soldering back the 4 wires and you're done!
    • This step requires soldering. Only do this step if you are OK with soldering small wires.
Ligne d'arrivée
Steven Clark
Membre depuis le 01/21/10
29 Réputation
2 tutoriels rédigés
Équipe
Cal Poly, Team 16-32, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 16-32, Maness Winter 2010
CPSU-MANESS-W10S16G32
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,540
