Ce dont vous avez besoin
Turn over the phone so the front screen is facing down and the back side is up.
To install the new battery, position the battery so that the three small metal contacts of the battery are facing the three metal contacts of the phone
Insert the top of the battery, with the two plastic tabs, into their respective holes in the top
Then press down on the bottom of the battery and it should snap into place
First remove the battery by pulling the tab away from the device
Next remove the 5 rubber modules by gently prying underneath them. This will expose the screws underneath
Now, slide a plastic opening tool in between the two plastic pieces that form the outside of the back case
Gently work the plastic opening tool around the edge of the case to separate the two pieces
Once the case has been separated you should be able to see the circuitry inside the phone
