Aller au contenu principal
LG Watch Urbane Battery Case Replacement
Ce dont vous avez besoin
  1. LG Watch Urbane Battery Case  Replacement, Battery: étape 1, image 1 de 2 LG Watch Urbane Battery Case  Replacement, Battery: étape 1, image 2 de 2
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Battery Case  Replacement: étape 2, image 1 de 2 LG Watch Urbane Battery Case  Replacement: étape 2, image 2 de 2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Battery Case  Replacement: étape 3, image 1 de 3 LG Watch Urbane Battery Case  Replacement: étape 3, image 2 de 3 LG Watch Urbane Battery Case  Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Battery Case  Replacement: étape 4, image 1 de 3 LG Watch Urbane Battery Case  Replacement: étape 4, image 2 de 3 LG Watch Urbane Battery Case  Replacement: étape 4, image 3 de 3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
  5. LG Watch Urbane Battery Case  Replacement, Battery Case: étape 5, image 1 de 2 LG Watch Urbane Battery Case  Replacement, Battery Case: étape 5, image 2 de 2
    • Use the PH000 screwdriver to remove the two highlighted screws to release the battery
  6. LG Watch Urbane Battery Case  Replacement: étape 6, image 1 de 1
    • Carefully pinch out the battery case with your fingers to remove it from the face of the watch.
Philip Sears
Membre depuis le 08/31/15
192 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-4, Remmell Fall 2015 Membre de l'équipe USF Tampa, Team 1-4, Remmell Fall 2015
USFT-REMMELL-F15S1G4
4 membres
4 tutoriels rédigés
Un commentaire
Where to buy a battery to replacement
sdptuananh - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 3
Total : 1,056
