Aller au contenu principal
LG Watch Urbane Battery Replacement
Ce dont vous avez besoin
  1. LG Watch Urbane Battery Replacement, Battery: étape 1, image 1 de 2 LG Watch Urbane Battery Replacement, Battery: étape 1, image 2 de 2
    • Push on the band in order to expose the pins
    • Using tweezers, remove the pins, one on each side, in order to only leave the face of the watch.
  2. LG Watch Urbane Battery Replacement: étape 2, image 1 de 2 LG Watch Urbane Battery Replacement: étape 2, image 2 de 2
    • Using plastic opening tools, carefully pry open the back cover of the the watch.
    • Use the little hatch on the bottom portion of the watch in order to easily pry open the watch
  3. LG Watch Urbane Battery Replacement: étape 3, image 1 de 3 LG Watch Urbane Battery Replacement: étape 3, image 2 de 3 LG Watch Urbane Battery Replacement: étape 3, image 3 de 3
    Outil utilisé dans cette étape :
    Magnetic Project Mat
    $19.95
    J'achète
    • Using a PH000 screwdriver, remove the three screws in order to release the motherboard from the watch.
    • Do not lose the three screws! Keep them somewhere you will remember! A magnetic mat can help with this. Ifixit Magnetic Mat
    • Using plastic opening tools, remove the four connectors attached to the motherboard
  4. LG Watch Urbane Battery Replacement: étape 4, image 1 de 3 LG Watch Urbane Battery Replacement: étape 4, image 2 de 3 LG Watch Urbane Battery Replacement: étape 4, image 3 de 3
    • Using the plastic opening tools, carefully lift up the motherboard.
    • IGNORE THIS STEP IF ONLY REMOVING MOTHERBOARD: Use the plastic opening tools to carefully remove the battery
18 autres ont terminé cette réparation.
Rey Diaz
Membre depuis le 08/31/15
699 Réputation
2 tutoriels rédigés
Équipe
USF Tampa, Team 1-4, Remmell Fall 2015 Membre de l'équipe USF Tampa, Team 1-4, Remmell Fall 2015
USFT-REMMELL-F15S1G4
4 membres
4 tutoriels rédigés
11 commentaires
"pried" not "pryed"
Patty Remmell - Réponse
Where do I find a replacement battery?
nickpfau - Réponse
Found mine on ebay. Search for BL-S3 battery.
Atreidae -
The reassembly requires gluing the back together. How do you get the glue?
jiteshshahin - Réponse
There is glue around cover. I suppose when closing we should add glue to be waterproof again? Nothing about it in the guide, beside that ok.
Imx - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 5
7 derniers jours : 9
30 derniers jours : 40
Total : 15,367
