Aller au contenu principal
LG Xenon Battery Replacement
  1. LG Xenon Battery Replacement, Back Case: étape 1, image 1 de 1
    • Turn the phone over so the back side is facing you.
  2. LG Xenon Battery Replacement: étape 2, image 1 de 2 LG Xenon Battery Replacement: étape 2, image 2 de 2
    • Placing your thumb on the bottom of the phone, apply pressure to the small ridge in the middle of the phone and push upward towards the camera.
    • The back casing should slide off.
  3. LG Xenon Battery Replacement, Battery: étape 3, image 1 de 2 LG Xenon Battery Replacement, Battery: étape 3, image 2 de 2
    • Using your index finger, pull the top of the battery out first. Place your finger at the top center of the battery in the gap that is provided. Then pull the battery towards yourself.
    • The battery should easily fall out after the top of the battery has been pulled out.
Micaela Saqui
Membre depuis le 04/19/12
39 Réputation
7 tutoriels rédigés
Équipe
Cal Poly, Team 9-41, Regan Spring 2012 Membre de l'équipe Cal Poly, Team 9-41, Regan Spring 2012
CPSU-REGAN-S12S9G41
5 membres
16 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 1,294
