Aller au contenu principal
Large Animal Water Nipple Replacement
Ce dont vous avez besoin
  1. Large Animal Water Nipple Replacement, Large Animal Water Nipple: étape 1, image 1 de 1
    • Empty the container of all water.
  2. Large Animal Water Nipple Replacement: étape 2, image 1 de 1
    • With an adjustable wrench, unscrew the nut on the inside located near the base on the backside of the nipple.
  3. Large Animal Water Nipple Replacement: étape 3, image 1 de 1
    • Pull the mechanism out from the front.
  4. Large Animal Water Nipple Replacement: étape 4, image 1 de 1
    • Ensure there is no damage to the hole that needs to be patched.
    • Cracks or fractures are easily made due to sun damage or forcing the mechanism in or out.
  5. Large Animal Water Nipple Replacement: étape 5, image 1 de 1
    • Use Teflon tape to line the threads of the new nipple.
  6. Large Animal Water Nipple Replacement: étape 6, image 1 de 2 Large Animal Water Nipple Replacement: étape 6, image 2 de 2
    • Place the new nipple in the hole with the peg on top.
  7. Large Animal Water Nipple Replacement: étape 7, image 1 de 1
    • Fill the container slightly to ensure that there are no leaks. Tighten the washer or pull out to see if a crack has formed while replacing.
    • Tighten the washer to see if that is the source of the leak. If not, pull out to see if a crack has formed while replacing.
    • This is a leak in the seal.
  8. Large Animal Water Nipple Replacement: étape 8, image 1 de 1
    • If there is a leak try placing some more Teflon tape. If this does not fix the issue continue reading this step. If there is no longer a leak, move on.
    • Leaking from cracks are easily filled with caulking if the container is small. This would only be a temporary fix on a larger container. Due to the weight of the water, the barrel or bucket would need to be replaced.
  9. Large Animal Water Nipple Replacement: étape 9, image 1 de 1
    • Place and thread the nut on the inside of the container on the backside of the nipple.
  10. Large Animal Water Nipple Replacement: étape 10, image 1 de 1
    • Finally, place the container in the designated place and fill completely.
Ligne d'arrivée
Katelyn Root-Nelson
Membre depuis le 04/11/19
181 Réputation
1 tutoriel rédigé
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 201
