Aller au contenu principal
Laser Lens Cleaning
Ce dont vous avez besoin
  1. Laser Lens Cleaning, Top Panel: étape 1, image 1 de 2 Laser Lens Cleaning, Top Panel: étape 1, image 2 de 2
    • Remove four 7.5 mm Phillips screws on the both sides (2 on each side).
    • Remove five 7.5 mm Phillips screws on the back of the player.
    When i put in a dvd the dvd player want open
    I have to unplug it and plug it back in, so it
    will open. If I don't put a dvd in it opens and'
    closes fine. What's causing this ?
    John Bailey - Réponse
  2. Laser Lens Cleaning: étape 2, image 1 de 2 Laser Lens Cleaning: étape 2, image 2 de 2
    • Lift the top panel from the back and remove. It should come off without being forced. There is a lip near the front so you many need to slide the top panel back slightly to remove it.
  3. Laser Lens Cleaning, Laser Lens Cleaning: étape 3, image 1 de 2 Laser Lens Cleaning, Laser Lens Cleaning: étape 3, image 2 de 2
    • Locate the lens on the disc drive.
    • Make sure that there is no dust on or near the player and area you are working on. Dust can get on the lens and scratch it while you are cleaning. It is very important that the lens is not damaged because the lens is used to read the discs.
    • Dip one end of a cotton swab in rubbing alcohol.
    • Lightly dab the swab on the lens. Be very gentle.
    • Let the lens dry before replacing the top plate of the DVD player.
12 autres ont terminé cette réparation.
Nathan Klammer
Membre depuis le 10/06/11
461 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 21-20, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 21-20, Maness Fall 2011
CPSU-MANESS-F11S21G20
4 membres
7 tutoriels rédigés
3 commentaires
This item was not appropriate, thank you for trying.
bigd734 - Réponse
Works on Samsung's box(home theater), thank you!
CarlBraun - Réponse
It worked on my cheap player. This unit is on 24/7. The dust in the house is heavy and smokers so the fix is cheap and I picked up a few things. Thanks
Seeker - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 13
7 derniers jours : 88
30 derniers jours : 356
Total : 48,236
