Aller au contenu principal
Introduction
The default values of the PS1 drives are between 940 - 970 ohms. To read burned CDs you have to go down a bit.
Warning ! Before you work on the open console, be sure to remove the power! Pull the plug!
Reducing the resistance, will increase the wear and tear of the laser ! If you go down in steps of ten and the CD is read correctly do not further reduce the value, that is useless.
CD's MUST be burned with a maximum burning speed of 4x, because the PS1 laser cannot deal with burn errors. If your burner only supports higher speeds, get another one, because then the games will most likely not work.
This Tweak is intended for 7000er consoles (750x, 700x)! Other PS1 consoles may have a bias & gain on the motherboard. If this value is adjusted then there are other instructions for it.
Instructions vidéo
Feedback and constructive criticism desired.
3 autre(s) ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
TheSupport
Membre depuis le 27/03/2016
71 Réputation
1 tutoriel rédigé
Swap to German ( ENGLISH TRANSLATION)
The default values ​​of the PS1 drives are between 940 - 970 ohms. To read burned CDs you have to go down a bit.Attention ! Before working on the open console, be sure to take the POWER away! Pull the plug!If you reduce the resistance value, the wear of the laser is increased! If you go down in steps of ten and the CD is read correctly does not reduce the value, that does not help.CD's MUST be burned with a maximum burning speed of 4x, because the PS1 laser with burn errors are not clear. If your burner only supports higher speeds, get another one, because then the games will most likely not work.This Tweak is for 7000er consoles intended (750x, 700x)! Other PS1 consoles may have a bias & gain on the motherboard. If this value is adjusted then there are other instructions for it.
Jordon Garcia - Réponse
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 32
Total : 722
