Aller au contenu principal
Lasko 2002W Motor Replacement
Ce dont vous avez besoin
  1. Lasko 2002W Motor Replacement, Remove cover: étape 1, image 1 de 1
    • Remove the front cage from the fan, exposing the screws.
  2. Lasko 2002W Motor Replacement, Remove screws: étape 2, image 1 de 1
    • Remove the 3 screws holding the fan on to the motor housing using a 3/16" philips head screw driver. The length of the screwdriver does not matter.
  3. Lasko 2002W Motor Replacement, Remove motor screws: étape 3, image 1 de 1
    • Remove the screws holding the motor onto the fan using the same 3/16" phillips head screwdriver. There are two screws.
    • Once removed, remove the metal part the screws were holding to the motor.
  4. Lasko 2002W Motor Replacement, Remove old motor.: étape 4, image 1 de 1
    • Remove the old motor from the fan. No tools are required. The motor can simply be pulled out.
  5. Lasko 2002W Motor Replacement, Place new motor in motor housing.: étape 5, image 1 de 1
    • Now that the old motor is removed, a new motor can be placed in the motor housing.
9 autres ont terminé cette réparation.
elsa
Membre depuis le 10/11/14
382 Réputation
1 tutoriel rédigé
Équipe
USF Tampa, Team 1-39, Donnelly Fall 2014 Membre de l'équipe USF Tampa, Team 1-39, Donnelly Fall 2014
USFT-DONNELLY-F14S1G39
1 membre
1 tutoriel rédigé
Un commentaire
What is the part number for replacement motor? Where do you get it?
Paul Dias - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 7
Total : 3,743
