Aller au contenu principal
LeapFrog LeapPad Ultra Repair Motherboard Replacement
Ce dont vous avez besoin
  1. LeapFrog LeapPad Ultra Repair Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 2, image 1 de 1
    • Remove the two 5 mm screws that were covered by the sticker.
  3. LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 3, image 1 de 1
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 4, image 1 de 1
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 5, image 1 de 1
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 6, image 1 de 2 LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 6, image 2 de 2
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  7. LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: étape 7, image 1 de 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: étape 7, image 2 de 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement, Motherboard: étape 7, image 3 de 3
    • Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
  8. LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 8, image 1 de 2 LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 8, image 2 de 2
    • Unscrew the five screws holding the motherboard into the housing.
  9. LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 9, image 1 de 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 9, image 2 de 3 LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 9, image 3 de 3
    • Lift the motherboard up exposing the fourth and final wire. Once you lift up the motherboard you will need to pull down on the wire to disconnect.
  10. LeapFrog LeapPad Ultra Repair Motherboard Replacement: étape 10, image 1 de 1
    • Remove and replace motherboard.
Rocky Hirsch
Membre depuis le 08/27/15
848 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 4-99, Meier Fall 2015 Membre de l'équipe USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
4 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 8
Total : 1,502
