Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
A damaged screen inhibits view and touchscreen functionality of the device. A screen replacement is necessary when the damage to the screen prevents the device from being used to its maximum capacity. When following this guide, be careful not to cause harm to any of the other internal components as they are very fragile.
  1. Remove the barcode covering the two screws on the lower back of the Leap Pad.
    • Remove the barcode covering the two screws on the lower back of the Leap Pad.
  2. Remove the two 5 mm screws that were covered by the sticker.
    • Remove the two 5 mm screws that were covered by the sticker.
  3. Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
    • Using a plastic opening tool, pry off the outer protective child proof casing, starting from the bottom.
  4. Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
    • Remove the 7 mm screw to the right of the cartridge dock, two 8 mm screws in the top left, and the nine 8 mm screws holding the the green shell.
  5. Remove the hard plastic casing, exposing the motherboard and battery.
    • Remove the hard plastic casing, exposing the motherboard and battery.
  6. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  7. Disconnect the battery using tweezers or your fingernails. The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Disconnect the battery using tweezers or your fingernails.
    • The battery is glued down, if available put some isopropyl alcohol around the edges of the battery to soften the glue.
    • Gently pry of the battery lose using a spudger or another thin prying tool.
    • Be careful, damaging/puncturing the battery may cause an explosion.
  8. Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically. Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically. Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
    • Disconnect the three wires that will be visible on top of the motherboard. The wires need to be disconnected by pulling them up vertically.
  9. Unscrew the four screws holding the motherboard into the housing. Unscrew the four screws holding the motherboard into the housing.
    • Unscrew the four screws holding the motherboard into the housing.
  10. Lift the motherboard up exposing the fourth and final wire. Once you life up the motherboard you will need to pull down on the wire to disconnect. Lift the motherboard up exposing the fourth and final wire. Once you life up the motherboard you will need to pull down on the wire to disconnect. Lift the motherboard up exposing the fourth and final wire. Once you life up the motherboard you will need to pull down on the wire to disconnect.
    • Lift the motherboard up exposing the fourth and final wire. Once you life up the motherboard you will need to pull down on the wire to disconnect.
  11. Remove and replace motherboard.
    • Remove and replace motherboard.
  12. Remove the side grips simply pulling them both vertically exposing eight screws. Remove the side grips simply pulling them both vertically exposing eight screws.
    • Remove the side grips simply pulling them both vertically exposing eight screws.
  13. Using the screwdriver with the PH1 bit, unscrew all nine of the exposed screws holding the plastic base down and remove the base.
    • Using the screwdriver with the PH1 bit, unscrew all nine of the exposed screws holding the plastic base down and remove the base.
  14. Using the screwdriver with the PH00 bit, unscrew the twelve screws holding the screen casing down.
    • Using the screwdriver with the PH00 bit, unscrew the twelve screws holding the screen casing down.
  15. Separate the screen from the casing and circuit board.
    • Separate the screen from the casing and circuit board.
  16. Replace screen.
    • Replace screen.
9 autre(s) ont terminé cette réparation.
Rocky Hirsch
Membre depuis le 27/08/2015
794 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 4-99, Meier Fall 2015 Membre de l'équipe USF Tampa, Team 4-99, Meier Fall 2015
USFT-MEIER-F15S4G99
4 membres
10 tutoriels rédigés
I need a source for the LCD screen. Anyone have a connection?
rhilscher - Réponse
Where would i purchase the new screen?
gaildavies282 - Réponse
You cannot get the screens. I had to get one from a parted device. Best you could try for is finding one the correct size with the connector in the proper place that is 50 pin.
crhouk - Réponse
I bought mine on eBay for 15.00.
Joel Marcarelli - Réponse
Could you send the link to where you bought yours
Michelle Popoff -
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 3
7 derniers jours : 37
30 derniers jours : 145
Total : 11,879
