Introduction
Are your selfies not showing up? Replace your front camera to see how beautiful you are.
This guide will require soldering equipment and skill.
Ce dont vous avez besoin
Before disassembling your LeapPad, ensure your device is shut off.
Push outward on the plastic side panels to remove and reveal battery.
The panels should detach fully from the main device.
Remove the following screws securing the back cover to the main device:
Two 10.0 mm Phillips screws
Four 4.0 mm Phillips screws
Three 3.0 mm Phillips screws
Remove the following screws securing the front cover to the main device:
Three 6.0 mm Phillips screws
Three 7.0 mm Phillips screws
Three 7.0 mm Phillips screws (bulkier screw head than other 7.0 mm Phillips screws)
Lift the screen from the motherboard by pulling the board out from the three metal tabs.
