Aller au contenu principal
LeapFrog LeapTV Controller Button Replacement
Ce dont vous avez besoin
  1. LeapFrog LeapTV Controller Button Replacement, Battery: étape 1, image 1 de 1
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Button Replacement: étape 2, image 1 de 1
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Button Replacement: étape 3, image 1 de 1
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Button Replacement, Buttons: étape 4, image 1 de 1
    • Use the screwdriver to remove the eight 8.7mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Button Replacement: étape 5, image 1 de 1
    • Slightly lift up on the back cover until the handle covers are free to rotate.
  6. LeapFrog LeapTV Controller Button Replacement: étape 6, image 1 de 1
    • Slide the the side of the handle facing you to the left to reveal the "A" and "B" button circuit board.
  7. LeapFrog LeapTV Controller Button Replacement: étape 7, image 1 de 1
    • Use the screwdriver to remove the three 8.5mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Button Replacement: étape 8, image 1 de 1
    • Lift up on the circuit board and move it to the side.
    • Be careful to not cause excess stress to the connecting wires when handling the circuit board. Excess stress can cause solder points to break.
  9. LeapFrog LeapTV Controller Button Replacement: étape 9, image 1 de 1
    • Use the plastic opening tool to release the buttons from the controller casing.
  10. LeapFrog LeapTV Controller Button Replacement: étape 10, image 1 de 1
    • Remove the "A" and "B" buttons by pulling up on one of the buttons.
  11. LeapFrog LeapTV Controller Button Replacement: étape 11, image 1 de 1
    • Buttons are now removed.
Triston Fischer
Membre depuis le 03/08/17
128 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S4-G2, Baechle Spring 2017 Membre de l'équipe IUPUI, Team S4-G2, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 14
Total : 358
