Aller au contenu principal
LeapFrog LeapTV Controller Joy Stick Replacement
Ce dont vous avez besoin
  1. LeapFrog LeapTV Controller Joy Stick Replacement, Battery: étape 1, image 1 de 1
    • Use the Metal Spudger to push the release clip on the battery cover.
  2. LeapFrog LeapTV Controller Joy Stick Replacement: étape 2, image 1 de 1
    • Lift the cover off.
  3. LeapFrog LeapTV Controller Joy Stick Replacement: étape 3, image 1 de 1
    • The battery holder is now visible with the removal of the cover.
  4. LeapFrog LeapTV Controller Joy Stick Replacement, Controller Joy Stick: étape 4, image 1 de 1
    • Use the screwdriver to remove the eight 8.7 mm PH1 Phillips head screws.
  5. LeapFrog LeapTV Controller Joy Stick Replacement: étape 5, image 1 de 1
    • Separate the top and bottom parts of the controller slightly.
  6. LeapFrog LeapTV Controller Joy Stick Replacement: étape 6, image 1 de 1
    • Slide the cover on the back side of the controller covering the joy stick out of the way.
  7. LeapFrog LeapTV Controller Joy Stick Replacement: étape 7, image 1 de 1
    • Use the screwdriver to remove the four 8.7 mm PH1 Phillips head screws.
  8. LeapFrog LeapTV Controller Joy Stick Replacement: étape 8, image 1 de 1
    • Turn and lift the circuit board with button attacked out of the hole. Do not detach the circuit.
  9. LeapFrog LeapTV Controller Joy Stick Replacement: étape 9, image 1 de 1
    • Hold the circuit board and button and pull the button off.
  10. LeapFrog LeapTV Controller Joy Stick Replacement: étape 10, image 1 de 1
    • Joystick will now pop off.
Joshua Jones
Membre depuis le 03/23/17
101 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S4-G2, Baechle Spring 2017 Membre de l'équipe IUPUI, Team S4-G2, Baechle Spring 2017
IUPUI-BAECHLE-S17S4G2
3 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 16
Total : 764
