Aller au contenu principal
LeapFrog Scribble and Write Eraser Slider Cleaning
Ce dont vous avez besoin
  1. LeapFrog Scribble and Write Eraser Slider Cleaning, Eraser Slider: étape 1, image 1 de 1
    • Turn the toy over so the back is facing upward.
  2. LeapFrog Scribble and Write Eraser Slider Cleaning: étape 2, image 1 de 1
    • Using a Phillips #0 screwdriver, carefully remove all 9 screws.
    • Set aside screws in a safe place for later reassembly.
  3. LeapFrog Scribble and Write Eraser Slider Cleaning: étape 3, image 1 de 1
    • Remove the back of the toy by carefully lifting it up.
  4. LeapFrog Scribble and Write Eraser Slider Cleaning: étape 4, image 1 de 2 LeapFrog Scribble and Write Eraser Slider Cleaning: étape 4, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the two screws that secure the screen to the motherboard.
    • Set aside screws in a safe place.
    • Gently remove the motherboard to expose the display screen and eraser slider.
  5. LeapFrog Scribble and Write Eraser Slider Cleaning: étape 5, image 1 de 1
    • Carefully remove the display screen, leaving the eraser slider attached.
  6. LeapFrog Scribble and Write Eraser Slider Cleaning: étape 6, image 1 de 2 LeapFrog Scribble and Write Eraser Slider Cleaning: étape 6, image 2 de 2
    • Use the Phillips #0 screwdriver to remove the eraser slider.
  7. LeapFrog Scribble and Write Eraser Slider Cleaning: étape 7, image 1 de 1
    • Lastly, use a soft towel to clean the eraser slider, removing any debris.
    • When all previous seven steps are completed, go backwards and re-screw and put together your The LeapFrog Scribble and Write
Shang
Membre depuis le 02/10/16
328 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Nance Spring 2016 Membre de l'équipe USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 18
Total : 706
