Aller au contenu principal
LeapFrog Scribble and Write Motherboard Replacement
Ce dont vous avez besoin
  1. LeapFrog Scribble and Write Motherboard Replacement, Motherboard: étape 1, image 1 de 1
    • Use a Phillips head screwdriver to remove the screw from the battery compartment on the back of the toy.
  2. LeapFrog Scribble and Write Motherboard Replacement: étape 2, image 1 de 1
    • Remove the back battery cover and all of the batteries.
  3. LeapFrog Scribble and Write Motherboard Replacement: étape 3, image 1 de 1
    • Use a Phillips screwdriver to remove the nine case screws from the back of the toy.
    • Be careful to keep track of the screws.
  4. LeapFrog Scribble and Write Motherboard Replacement: étape 4, image 1 de 1
    • Remove the back cover from your toy.
  5. LeapFrog Scribble and Write Motherboard Replacement: étape 5, image 1 de 1
    • Using a Phillips screwdriver, remove the four screws from the motherboard.
  6. LeapFrog Scribble and Write Motherboard Replacement: étape 6, image 1 de 1
    • Remove the keyboard ribbon from the motherboard.
  7. LeapFrog Scribble and Write Motherboard Replacement: étape 7, image 1 de 1
    • Remove the speaker wires from the motherboard with your soldering iron.
  8. LeapFrog Scribble and Write Motherboard Replacement: étape 8, image 1 de 1
    • Remove the battery wires from the motherboard with the soldering iron.
  9. LeapFrog Scribble and Write Motherboard Replacement: étape 9, image 1 de 1
    • Remove the switch wires from the motherboard with the soldering iron.
  10. LeapFrog Scribble and Write Motherboard Replacement: étape 10, image 1 de 1
    • Remove the pen wires from the motherboard with the soldering iron.
  11. LeapFrog Scribble and Write Motherboard Replacement: étape 11, image 1 de 1
    • Remove the volume control switch from the motherboard with the soldering iron.
Shang
Membre depuis le 02/10/16
328 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 1-5, Nance Spring 2016 Membre de l'équipe USF Tampa, Team 1-5, Nance Spring 2016
USFT-NANCE-S16S1G5
3 membres
10 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 10
30 derniers jours : 17
Total : 680
