Aller au contenu principal
Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide
Ce dont vous avez besoin
  1. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Battery: étape 1, image 1 de 1
    • Flip over device so that back portion of the device is facing you.
  2. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 2, image 1 de 1
    • Unscrew the one 10mm screw that holds the battery cover in place with a a PH1 phillips head screwdriver.
    • Please note that the screw cannot be removed as it is attached to the battery cover.
  3. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 3, image 1 de 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 3, image 2 de 2
    • Carefully pry the batteries out with a plastic opening tool prying from the non spring side.
    • Remove the three AA batteries.
    • Note the direction of the batteries for when reassembling.
  4. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide, Keyboard Buttons: étape 4, image 1 de 1
    • Remove the eleven 10mm screws from the back of the device with a a PH1 phillips head screwdriver.
  5. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 5, image 1 de 1
    • Carefully remove back of the device.
    • Make sure not to rip the wires when lifting the cover off.
  6. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 6, image 1 de 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 6, image 2 de 2
    • Remove the three 10mm screws from the upper left hand corner white plastic piece with a PH1 phillips head screwdriver.
    • Unscrew the five 4mm screws from the plastic membrane with a PH1 phillips head screwdriver.
  7. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 7, image 1 de 1
    • Remove the white plastic piece and place it to the side.
  8. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 8, image 1 de 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 8, image 2 de 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 8, image 3 de 3
    • Gently grab the membrane and peal it upwards.
    • Carefully remove the membrane and set it to the side.
    • From this step you can also clean the membrane of any residue with a lightly dampened paper towel.
    • Ensure that the membrane is completely dry before reassembly.
  9. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 9, image 1 de 2 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 9, image 2 de 2
    • Gently lift and remove the foam piece
  10. Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 10, image 1 de 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 10, image 2 de 3 Leapfrog My Own Leaptop Keyboard Buttons Replacement Guide: étape 10, image 3 de 3
    Outil utilisé dans cette étape :
    • From here, each button is able to be removed for cleaning or replacement.
    • Using a tweezers or needle nose pliers, remove the necessary pieces from the device.
2 autres ont terminé cette réparation.
Jonathan Fitzer
Membre depuis le 02/10/16
584 Réputation
3 tutoriels rédigés
Équipe
USF Tampa, Team 14-6, Lacy Spring 2016 Membre de l'équipe USF Tampa, Team 14-6, Lacy Spring 2016
USFT-LACY-S16S14G6
4 membres
6 tutoriels rédigés
6 commentaires
Very useful. but where to get a new membrane? please help
Alina Timchenko - Réponse
Didn't work. I'll buy a new toy.
victoria_nglover19 - Réponse
Is the screen on this suppose to light up?
stewartmelinda41 - Réponse
I was wondering if the screen is suppose to light up because the one I have doesnt
thank you very much
Njabulo Mbele - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 7
30 derniers jours : 25
Total : 5,559
