Aller au contenu principal
Lego Dimensions Starter Pack USB Cable Replacement
Ce dont vous avez besoin
  1. Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: étape 1, image 1 de 2 Lego Dimensions Starter Pack USB Cable Replacement, Top Cover Parts: étape 1, image 2 de 2
    • Be careful not to crack the cover.
    • Use the metal spudger to gently pry open the corners of the top cover.
  2. Lego Dimensions Starter Pack USB Cable Replacement: étape 2, image 1 de 1
    • Be careful not to crack the top cover.
    • Use the metal spudger to gently pry up the center of the top cover.
  3. Lego Dimensions Starter Pack USB Cable Replacement: étape 3, image 1 de 1
    • Pull the top cover off.
  4. Lego Dimensions Starter Pack USB Cable Replacement: étape 4, image 1 de 1
    • Lift up the circular illumination stand and remove it from the toy pad.
  5. Lego Dimensions Starter Pack USB Cable Replacement: étape 5, image 1 de 1
    • Lift up the white L-shaped pieces and remove them from the toy pad.
  6. Lego Dimensions Starter Pack USB Cable Replacement, USB Cable: étape 6, image 1 de 1
    • Pull the white connector away from the motherboard, keeping the white connector parallel to the board.
    • You may need to use a plastic opening tool or spudger to help separate the connector. Avoid pulling firmly on the wires themselves.
    • Remove the USB cable from the toy pad.
3 autres ont terminé cette réparation.
Alyssa Lach
Membre depuis le 11/06/17
509 Réputation
4 tutoriels rédigés
Équipe
IUPUI, Team S5-G2, Baechle Fall 2017 Membre de l'équipe IUPUI, Team S5-G2, Baechle Fall 2017
IUPUI-BAECHLE-F17S5G2
2 membres
8 tutoriels rédigés
2 commentaires
Where do you buy the USB cable from?
jaimea371 - Réponse
mguzmanv - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 8
30 derniers jours : 56
Total : 5,489
