Introduction
Use this guide to replace the Flash Diffuser.
Ce dont vous avez besoin
Carefully unscrew the four Phillips #0 screws on the bottom of the camera.
Open the back door on the camera by pushing down on the door latch.
Apply pressure to the bottom plate and it will pop off.
From here, you can replace the bottom plate, or continue on to further steps.
Now that you've removed the bottom plate, you can pull apart the front and back covers.
Start with the front cover and, by applying pressure (perhaps a lot of pressure), snap off the front cover.
